Edge case for side grip
Kalvin Kerns
Trusted Member
Feb 14, 2014
1,586
Anyone have any idea if a thin case like an Incipio Feather case might fix the sharp, uncomfortable feel that the S6 Edge has?
I really like the Edge, but that sharp side edge where the glass meets the metal is very uncomfortable to hold.
The regular S6 feels better, so I'm trying to get that same comfortable hand feel on the Edge.
UAG Maverick is a great case. The only problem is that its very bulky. For the Note Edge, I bought a couple more cases. One is Iroo and the other is Otongke that I really like, I suspect that if they have them for the Note Edge they would have them for the S6 Edge.
Sounds good, thank you, but I definitely prefer the thinnest case possible. Naked would be best of course, but not with this phone especially since I'm trying to get that sharp edge feeling gone by using a case.
Wow thanks DeniseW! That looks really nice. I just wonder if it'll help make the edges less sharp and easier to hold.
Lol after seeing this case I'm still torn over the regular S6 or the Edge. This case looks like it might make holding it much better though.
You also might want to check out the clear version of the neo hybrid case: https://rover.ebay.com/rover/1/711-...709&mpre=http://www.ebay.com/itm/201307436311
In my experience, clear TPU cases are cool and nice for about a month or two then they turn brown/yellow. My experience may be due to cheaper manufacturers though.
Also, I realized I posted the wrong link above. As far as thin as possible, this might be your best choice: http://www.amazon.com/Galaxy-Spigen...ag=hawk-future-20&ascsubtag=UUacUvbUpU4315788
It will only make your phone 2 mm thicker. I personally really like the Spigen Neo Hybrid posted above and will probably get that one. It has great looks and looks like it has nice protection as well. I don't care as much about size as long as it's not an Otterbox size. This one is probably another 1-2mm thicker than the Spigen Slim though. As far as grip, the thicker Neo Hybrid will probably help with that.
I personally hope Caseology makes the Edge versions of these cases: http://www.caseologycases.com/collections/samsung-galaxy-s6/products/bumper-frame-case
I agree. I was disappointed that Caseology didn't have any edge cases. I liked the look of there S6 cases.
I got the Spigen Neo Hybrid case as well, and I received my phone Wednesday. It gives a great grip to the phone, doesn't cover the screen at all, and the rubberized button covers give me no issues. The back is textured to help with grip as well.
So far just using a Zagg InvisiShield HD screen protector I got at Best Buy which works well. I'm waiting on Amzer to get their tempered glass protectors back in stock to possibly try that as well.
Posted from my Galaxy S6 Edge
JOLOVELY24
