Edge feeds not working on galaxy S7 edge
  • Start date Start date
A
AC Question
Hi,
I did swipe the edge of darkened lock screen after previously turning edge feeds On, but I get no response, or I get a message saying " no new feeds". I've yet to get any feeds at all.
What can I do to fix this?
Thanks for any help you can offer, Carole
Hi,
Welcome to Android Central!
Are you just trying from the lock screen or does it not work when unlocked? Did you disable any Yahoo apps?
Your screen should be off, not on lockscreen. Do the swipe gesture. A clock/weather feed should appear. Swipe towards or away from the center of the screen to scroll thru the different feeds that you enabled in settings.
witnessloc12
