Edge not able to send or receive MMS messages while WIFI is on since update, help!
ScofieldReturns
4
It says something is wrong with the APN settings and any MMS messages being sent to me don't go through until I turn off the wifi.
Are you using a 3rd party messaging app like Textra? Some of those need a 'patch' for them to work with MMS. Also, have you tried disabling WiFi-calling and seeing if that helps? When WiFi calling is enabled, texting and MMS want to 'travel' through WiFi as well, just like calls do.
If you use the stock messaging app you get the same error? Have you called the carrier to have them re-send the configuration to your phone?
manthosstavrou
