Edge Panel - Soft Key Edge - Where did it go?
felloffthetruck
Trusted Member
Mar 31, 2013
8,616
24
38
I had an edge panel called "Soft Key Edge" that would let you do screenshots, power off the display ETC.
For the life of me I can no longer find this panel. Anyone know where it went or how I can get it on the N20U?
Is there another panel that is similar?
Thanks.
Thanks.
Someone said it wasn't ready for the note 20 or something like that. I'm using it and it's working fine. You have to download it from the link below if you want it
https://www.apkmirror.com/apk/samsu...ase/softkey-edge-1-0-02-android-apk-download/
Nope, I did not sideload. It's available directly from the galaxy app store.
You're in south africa it appears. He just said it wasn't in the store, so wondering if it's not available in the United States for some reason.
I used the link above and there no issues.
No members online now.
wobblefix
