Edge panels..or lack of them
trucksmoveamerica#AC
Trusted Member
Jul 20, 2010
8,888
1,877
113
I just got the fold 2 and I am using edge panels. What happened to downloading edge panels. It appears the only edge panels I can use are the ones that are there already. Usually you tap the edit button and galaxy store option is right there to download edge panels. I can't find them in the galaxy store either. I've got to be missing something samsung didn't really limit those did they?
Yes, they did limit it to the ones that are already there. Surprised me too.
That's a major set back for me on this phone. I used a panel called soft edge panel for screen shots to avoid the 2 handed button on the side. Damn why does samsung have to do stuff like this.
It will be better then nothing. I just had to delete 2 contacts off the list, replaced it with the screenshot and one hand mode. That will make the phone better for me. Still in the learning stages on this.
You can just keep adding no? There's no limit
