Emerson 543 tablet power button problem...
stermon
6
Hi all,so i have a emerson 543 tablet(basically the polariod PMID4311,rebranded)and i love it to be honest..nice little tablet for the price,but put it away the other day and the power button is now sunk in.,cant seem to get it out,anyone have this same problem?found a way of getting it out?know how to?my sons use it so all thair saved games will be gone if i cant fix it...hopefully someone can help.thanks in advance..
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Hi all,so i have a emerson 543 tablet(basically the polariod PMID4311,rebranded)and i love it to be honest..nice little tablet for the price,but put it away the other day and the power button is now sunk in.,cant seem to get it out,anyone have this same problem?found a way of getting it out?know how to?my sons use it so all thair saved games will be gone if i cant fix it...hopefully someone can help.thanks in advance..http://imageshack.us/scaled/modthumb/94/fidu.jpg
With the button sunk down you don't have the ability to still use it, right? You might need to remove the case (not sure how it's done on this device) and see what is wrong with the button hardware.
EvilMonkey
1,808
103
I'm not familiar with that tablet either. Might be able to take the case off (as suggested).
Can you pop it out with a pin or something?
STARGATE
Ambassador
Oct 8, 2012
6,660
62
48
My cousin has a small Android tablet (don't remember the name or brand) and he had a similar problem.
I yanked the power button up with a small knife, placed a piece of rubber under and then the power button back in place.
His tablet has had no problems since then.
If you try this though, be very careful!
A knife is a dangerous tool and could hurt you or anybody around you at that moment.
Sent From a Galaxy S4 Away!
stermon
6
yes but you cant put it in sleep mode,so battery dies real quick..gona have to try and open it i guess,thanks for the advice tho..
I'm not familiar with that tablet either. Might be able to take the case off (as suggested).no screws tho...so dont know...maybe pries it off i guess
tried small flathead,but it just see saws backwards and forwards...really wierd..
will try that if i can get button out,dont want to break the thing all together tho..cos all their saved games are on there,how would i copy the saved games over? if i can that is, to another android tablet?that would prolly work....
dumpsterrentals37
