ePHRD help?
Vlosaloty
120
I cant remember the number you dial to get the the ePHRD settings. Can someone help me out here? I think it was like 778 number and either # or * but not postive. Thank you guys so much
I saved ##778# as a contact. That way I don't need to remember it the next time I need to toggle off eHRPD. :)
Quick question....during the 4G outage I switched my phone over to Rev. A. After the outage I switched it back to eHPRD. However, when checking the phone info when I happen to be in a 3G area, the phone is still on Rev. A. I have switched back and forth a couple of times and done the reboot when committing changes. Anyone have any ideas?
Yup. VZW hasn't re-enabled eHPRD. Instead, we're all on Rev. A for the time being. The implications of this are when you travel from a 4G area to a 3G area, and vice versa, your IP address will change, This will interrupt anything streaming at the time. Voice goes over 1X, so that isn't affected, and you still have the ability to to talk and use data at the same time - again, because the tbolt uses separate radios for 1X, 3G and 4G.
We're all assuming that VZW is fixing whatever problem they had with eHPRD, and that fix is what's delaying the Samsung Charge.
Thanks. That was what I inferred, but I had not heard too much else about it. Thanks much for the info.
thetechbuyersus
