EVO 4G Antenna Location?
EvoBeevo
19
Anyone know where the antenna is in this bad boy? I'd like to demo a 'deathgrip' video of my own and would like to know where its' attenuation spot is...
Don't know, but you might be able to find it on the FCC web site.
FWIW, I downloaded a signal strength app, and while I saw some degradation depending on how I held it, it wasn't enough to cause even a 1 bar drop in the displayed signal.
The 'deathgrip' is on the top. Grip it with you right hand and you will see the bars start to drop. Worked every time for me.
Yep you are right at the top. Well its better there than at the bottom where we grab the phone mostly.
Sent from my PC36100 using Tapatalk
If you remove the rear battery cover, you can see the numerous antennas "taped" under the red vinyl stuck to the case. There is the main antenna, a wi-fi antenna, a bluetooth antenna, and I am guessing a broadcast wifi antenna.
One top left, one top right, one on the right side, and one on the bottom.
According to the user's manual (check your burrito bowl), if you look at the screen, the network antenna is in the top half, left third of the phone.
Kobelup
