Evo and PS3 using Evo connected to laptop?
storino03
885
11
Is this possible, using a stock Evo (non-rooted) and have it connected to my laptop and somehow use the wireless to connect my PS3 online?
Might have said it wrong. Is there a way to tether the PS3 using the Evo connected to my Laptop via USB? Not use the laptop at the same time, but as bridge.
OR
If there was a simple root method that I could use to enable wireless tethering on my Evo like the unrevoked method, which I think doesn't work on 2.2 anymore. Any ideas?
I believe you can USB tether directly to the ps3 with easy tether from the market. No root required
i am interested in seeing the performance of the PS3 while using the evo to play games online. Has anyone or is anyone currently doing this?
I haven't used the EVO but I have used my Galaxy Tab to play on my PS3. It is okay. Sometimes there is lag and it certainly isn't a great connection but since Verizon won't add any more dsl hookups in my neighborhood you gotta do what you gotta do to get by.
I have used the sprint hotspot from my Evo 4g to connect to Xbox live and play online with no problems, but am unable to connect to my PS3 because it does not have wireless capability (older backwards compatible model). So I am wondering how I can go about hooking my phone up directly to my PS3 so that I can, if nothing else, be able to visit the Playstation store for purchases and downloads as well as system updates. Any help is appreciated!
I'm not sure what's out there now but the app pdanet worked when I used it a couple of years ago. Might be better ones out there now, make sure it free. It you run across one that works with say..., the Xbox. It should work with the PS3 to.
Sent from my PC36100 using Android Central Forums
RichardDixon
