Evo Booting Problems
rdlaner
4
Hi,
I'm not really sure what just happened to my Evo and could use some help on figuring it out.
I use (used) Launcher Pro and was trying to load a flash image on the dolphin mini browser and it consistently failed and closed the browser. So, I restarted the phone in hopes to fix the issue. Instead, the phone got stuck on the "4G" start up image. I pulled the battery and tried to restart and after that the evo eventually booted up, but now most of the applications force close almost immediately after loading them, Launcher Pro is nowhere to be found, none of the widgets will load and in general all my settings have been lost. I can't update the market, many of the apps reverted back to old previous versions (ie facebook, android market, etc).
I really have no idea what could have caused this and am just as at a loss as to how to fix this.
Anybody have any thoughts, questions, insights, or suggestions???
Thanks!
Are you rooted or not rooted? If not have you tried doing a factory reset? If so have you tried wiping and reflashing your rom?
dextriminator
