Evo Problems Please Help
AndroidGuy2
5
I have had my Evo rooted previously and wanted to un-root it and install the stock rom so I could update to 2.3. I flashed the RUU and now I'm at 2.1. However, it says there are no updates and my phone is up to date. If anything, shouldn't I at least be prompted to update to 2.2? I'm at a loss for words here and extremely frustrated. I've searched and searched. Please help me!
Keep checking for an update.... its live now. You should be fine once HTC starts pushing out the 2.3 update to your area.
One question..... why did you unroot???
If you wanted 2.3 you should have just found a 2.3 custom rom(there's a bunch) or just waited a few hours for one of the devs to post a rooted version.
Depending on what HTC does with this update... it may be a while before you can get root back.
Sent From The Tree House Out Back!
I unrooted bc I don't really need to root. I did it just to try it. I like knowing that the stock roms usually work perfectly. I guess I will try that rooted stock rom. thanks!
can somebody please help, i used unrevoked 3 to root phone for wifi tether so i can use ipod touch over wifi for netflix, now that android has netflix i dont want root and just want to go back to good old days(stock) i never had unrevoked app in my library just superuser permission, i dont even kno if i hav full root or not. i just want stock so i can get official ota 2.3 tday pleeeease! thank u
Just a little FYI. Netflex is broke for the new ota. Also, unrevoked doesn't have an app. ;)
marksains61
