Extended battery and case(Seidio 4000mah)
SenseMonkey
1,773
15
So i was thinking on getting this battery for my phone cause i hate being stuck on my charger all day cause i dont have what you call average battery life. My phone will die in 3hours or less if im using it.. -________- so i just wanted to ask anyone about this battery,any helpful tips,and any personal reviews about this battery before i send 120 for it. Thanks.
Awesome! It is awesome! The phone is definitely sexier and sleeker without it. With it, it is a fully functional beast of a machine. It changes some of the angles of the phone with the extended back. It makes for a very comfortable feeling in the hand for one handed use. It is bulkier. It has been totally worth it.
I had an issue at some point where it seemed the case back had some cracks at the edges...nothing had happened to it. I emailed them and they sent a replacement back.
Later...much later, I slipped in a wet stairwell and the phone dropped three flights. It landed on the back case. Yes, it broke the case map. Because of the battery weight, it landed on the back instead of the screen...at least I believe that is why. I purchased two replacement backs and considered the battery the reason my phone was saved.
I do not work for them. I used their extended battery for my Palm Pre and bought it right away for my 3d.
Dave
I've purchased Seidio products many times, great company. However, I recently bought an extended battery from another company for much much less and it has been "rock solid"! 2 full days+ on one charge and loving it!
Laza Zcell $18.99 at Amazon
HushRA
