Extended battery case
ChevyNovaLN
598
57
www.ChevyNovaLN.com
Do we have one???
Yes :) This case works with or without an extended battery.
Set Your Location
Its 2 pieces. The middle picture shows the 'back' of the case, which had a pull-out stand (you can see it verticle in the middle of the back), and the holster part is shown on the right.
My brother just got it for his at the store here in Omaha. He had no plans for the holster, but the case is 'fine' and adds the stand that will hold the phone up vertically as well as horizontally.
spectre1006
261
15
I just checked it out the other day in a vzw store. the con of the case is that it doesn't cover the top and bottom too well.. it does however cover the corners. I'm dying for a extended battery case like u are
georgie
