Extended Battery?
Anyone have a recommendation for a extended battery for the Inspire 4G?
I'm new as of yest however so far what i've gathered and is going well for me is
Juice Defender
Advanced Task Killer
On top of that turning off auto sync and unless you need the crazy brightness (outside) drop it down some. Also turning off wireless unless you are intending to connect to a network, otherwise it always scans and uses battery.
I am very hesitant to buy any batteries that are made in China. They sometimes cut corners and make inferior products that can have disastrous results. Still $10 is a steal. I will stay away though. Also no reviews makes me walk away.
Are you actually experiencing better performance? It appears to have gotten very mixed reviews on Amazon.
I ordered that battery twice and received a thunderbolt extended battery twice, I wouldn't bother with it.
Yes i am. It is not as a big difference as the 3500mah battery for my evo. But there is indeed a difference for my inspire.
Sent from my EVO using Tapatalk
Root your phone.. haha before i rooted i couldn't even get 6 hours out of my phone on light use. Now I get like 12+ on heavy use. gotta love custom roms.
I'd rather not root as this is my first android device and I have no clue what I'm doing.
mpuckett1958
