External mic won't power up
Brian Johnson18
Bought a usb external mic for recording on phone. Plug it in but power light does not come on. When plugged into any other device (iPhone, laptop, Surface) it works fine. Just no power with my Samsung s20 FE. Any suggestions?
Is your usb port set to charge only?
Sent from my Pixel 6 using Tapatalk
When you connect the mic, do you see a USB Connection notification? If so, tap that and see what options you get.
LEricG
