External SD and Micro SD card reader for android phones
May 16, 2013
5
Hi Guys,
We just posted a new project called ?GO on Kickstarter. Its a Micro USB based SD and Micro SD card reader for your android device. It can be attached behind your device and used as a card reader. Works with most of your android devices with 4.1.2 and higher and Rooted devices under 4.0
It also has an Auxiliary Micro USB port for charging and sync...
Check it out on Kickstarter
I know.. But that was just with a micro SD card.. We have been working on this product for 8 months.. This product has 3 features, SDHC card reader, Micro SD card reader and Micro USB port.. so you dont have to carry your card reader in your key chain / pocket and you can always keep it attached with your SD / Micro SD card reader attached.. Its like having an extension to your phone.. Also you dont need to remove the card reader to charge your phone, the auxiliary port lets you do that..
We were planing to post this on kickstart for 3 months but kept postponing it to improve the Auxiliary.. untill the micro SD card reader got posted.. bummer..
chadreich82
