External Speaker sound quality
roadrat
314
3
How is your external speaker (eg speaker phone, music, etc) sound quality?
Got my Dinc2 on Friday and the sound quality is terrible. There's a buzzing sound almost as if the speaker is blown or loose.
My original Dinc had surprisingly good sound from the external speaker even at higher volumes.
Mine is fine. Actually it's much better compared to my original droid. I used to always have very choppy quality, but not really the case with the DINC2.
I'd return it for another IMO.
Mine sounds tinny when I turn it up loud.
My d2 speaker was way better
Sent from my ADR6350 using Tapatalk
maybe a little tinny but not terrible, its actually pretty decent sounding, just not the loudest
the only annoying part for me is the input port. i have to take my case off to fit certain headphones in it. even then it creates feedback and all sorts of other noises. I've only tried my Dr.Dre Beats works fine even with case on it, Car input jack straight ones are okay i have to take the case off, L shaped ones i have to take the case off and i can't move it or else it makes a really loud noise, Ipod headphones are okay makes noises only if it moves alot. anyone else have this problem?
AyseDogan
