- Sep 7, 2017
- 4
- 0
- 0
Hello, my Asus Zenfone 2 Laser with Android 6.0 that I recently got second hand has a problem that I can`t fix, the new battery I bought for it drains very fast, same with its old two batteries..So far I disabled all the apps I don`t need including google browser and all other google apps, updated all the apps that I use (no games or heavy load apps),disabled location and have 0 data usage in 2 weeks,dropped screen brightness to lowest, deleted the whole cache partition, factory reset the phone, but it still drains super fast, and yes,the new battery is good. Also,there are no apps that use alot of battery
Is this a hardware problem? Should I dump this unit and buy a new one from the store?
