False battery status after firmware update, 'phone modified' messagge when checking for updates
mbrn2
Hello!
Several days ago (I don't remember exactly when) I got message about firmware update, which I applied when I got to wi-fi and plugged my phone into the charger.
Few days later, battery started to act odd (not really the battery, but its icon to be precise):
- sometimes it says "Charged 100%" (or Charging if any other percentage) after unplugging it and the battery icon still has the "thunder"
- No sound when plugging out
- sometimes it returns to normal after a while, sometimes not
I reckoned it could be related to firmware update, so I went to Settings>About device>Software update>Check for updates in order to check if there's a fix, but I got the message: "Your device has been modified. Software updates are not available."
But what does it mean? I have never done any modifications on the device, at least that I'm aware of. I don't use odd applications, and I don't even know what is root and what does it do, so I reckon I haven't performed it.
Was the firmware update some kind of scam?
What can I do to fix it?
Model number is GT-I18190N, Android 4.1.2.
Please help...:'(
Hello and welcome to the forums!
4.1.2 does appear to be the latest stock firmware available for your model http://samsung-updates.com/device/?id=GT-I8190N but it does sound like something got borked when you loaded the recent update. You could try using the Kies software to reload the firmware or you could use a tool called Odin to manually load it.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
Hi!
Thanks for the welcome and the reply.
Now when I check for the updates, it says that it is up to date. I no longer get the modification message. Could the problem be mechanical instead of software related?
I still have the warranty for the device.
I'd recommend booting into Recovery mode and clearing the system cache and performing a Factory Reset - that should take care of any squirrelly behavior. (Be sure to backup your data using the Kies software or your tools of preference first.)
