Fastboot problem
Leart369
Active member
Aug 7, 2013
41
Hello buddies,
I am having a sort of problem with my M8.
Just to make it clear from the beginning I'm pretty much a noob in this.
So after I got my phone debranded byba rooting method and had twrp installed I wanted to flash the stock recovery in my device so I can get OTA updates.
The momental state of the device: stock firmware 1.54.401.10, S-On, tempered, unlocked bootloader.
At first everything was going fine, but when I typed the command to erase cache before flashing the recovery.img, cmd in my pc crashed.
Now when I connect my device, in cmd I can see it only when I check usb debugging, when it's unchecked there isn't any device on the list unauthorised like it should be.
When I enter the command to reboot into fastboot, my device just reboots and when I get into fastboot manually cmd doesnt recognize it.
Just to make clear I don't think it's the drivers fault, I installed/uninstalled them several times and tried it in another pc and the same thing happens.
Sent from my HTC One_M8
boone
