first responder help
  • Start date Start date
A
AC Question
My dispatch sends a text but it's a email adresdress how do I get it to have its own custom notification
Welcome to Android Central! Which messaging app are you using, the stock Messaging one?
I use Hangouts for SMS, and one possible way is to do the following:
1. After you get at least one text message from the email address, go to that conversation.
2. Tap the Menu button, then People & Options.
3. Make sure Notifications is turned on for the conversation, and then tap Chat Message Sound to select a specific tone.
Now, the next time you get a text from that email address (which will be added on to the conversation), it should play that specific notification tone.
I'm not sure if your stock Messaging app has a similar setting. You can play around with it to see if it has anything like what I just described on Hangouts. But at least you know Hangouts is an option--and you can make Hangouts your default SMS app as well.
