Fix for SimpleRoot 1-click
d2globalinc
19
This is for SimpleROOT for the v1.47.651.1 Update of the EVO 4G.
SimpleRoot 1 click can be found here:
Downloads | Simple Root
and downloaded here: http://myevo4g.net/simple/?file_id=3
After uncompressing, running it and installing its updates, download the attached one.zip file to this post - extract it into the folder you decompressed simpleroot in.. or just uncompress it, and copy the one.bat file and replace the one.bat file in the simpleroot program's folder.
There is an error in the original one.bat file so that it doesn't give enough time for the data to be updated on the SD after pushing to it..
Once you have replaced the one.bat file with the one attached to this post - you can then click on the Step 1 button in simpleroot and follow the instructions as usual.
- Hope this helps others - who are trying to root before going up to a 2.2 rom.
Good Luck!
- D2G
jafar
