[FIX] Sideways Android Logo Issue after ED01 Flash
neo1981
6
Hey Guys,
I too had the sideways ANDROID issue.. what it is is this,
That Flash does something odd to the bootanimation.zip file
in system/media/
Replace that file and it will be perfectly fine. Hope this helps you all! :)
Reactions: spinwizard
I too have this issue, it happen when you flash ED01 on top of SC29.2 in this case is what i did. From now on every time i flash something either start fresh or wipe dalvik once wipe cahe twice again wipe dalvik then go from there, always work for me.
I think the sideways "android" logo may be the boot animation for ED01. I did not take a look at the stock ED01 at all, so I only have Adrynalyne's debloated/deodexed to compare. If you flashed Adrynalyne's debloated/deodexed ROM, you would only see the sideways android at boot up. Coming from another ROM without a clean wipe, you may see the sideways Android over your previous boot animation.
Hey Guys,
in system/media/
this is just a simple bootanimation, there isn't anything wrong with it, it comes with ED01 odin flash. So your right if you want a new bootanimation either flash it in CWM or push it system/media.
ChrisAndroid
