Flash fix for CM7 RC 1.6.1
deesto
Active member
Apr 20, 2011
31
Wondering if there's an easy or known solution for fixing Flash player content in browsers for Thunderbolt CM7 ROMs? The only references I've seen so far are for changing individual permissions on plugin file system files, for each browser, and for each site. I'm trying to view _any_ Flash content on all the browsers I have, and none of them work. The YouTube app works fine, just can't view any Flash content through a browser.
I've tried a permissions fix via ROM Manager but that didn't help.
BTW, after upgrading to this version, this Flash problem seems to be my biggest complaint, which says a lot for the ROM especially compared to the VZW stock version.
Hi fatboy97,
Did you look at the OP's post in [ROM] CM7 for Thunderbolt. RC1.6.1 Updated 8-15 1:20AM EST???
-Flash Videos in browser only works with Flash version 10.2 < WORKAROUND/FIX HERE - Fix for Flash 10.3 on CM7 - CyanogenMod Forum
Yes, I did, and after typing that path in a terminal (which wasn't fun with the soft keyboard), I got "No such file or directory". The problem is "app_plugins" doesn't exist, which is what the second poster ran into as well:
There wasn't a response to address that.
Then I'd suggest either searching or posting your comments on XDA or RootzWiki... these are the threads that the programmers started, and sometimes answer themselves... or there are other very good suggestions found over there.
nemismom
