Fonts
Kane89
85
Hi, I recently updated to 6.0 and now I can't even find a font application that will work with this new software. I have a sprint note 4. Any suggestions would be appreciated.
Devil Dog
Hi Kane89!
I'm to assume you're talking about a 3rd party application, through the Google Play Store? If so, you might try contacting the developer of said app(s), they usually have support contact information within their app. Rule out the developers app; your phone may only require its Partition Cache to be cleared, and/or the dreaded Factory Reset, which solved most problems that follow the larger updates.
Hope this helps!
Chris
