Freedom Pro Keyboard- Connection Problems w/ LG Revolution
stuarth
5
Background information.
- Keyboard is paired with the phone
- I can select the Freedom Pro Keyboard in my keyboard settings menu
- Freedom Pro shows "Paired but not connected" in the Bluetooth setting section
- Selecting the Freedom Pro Keyboard to connect does nothing. Same thing with devices result in a 'connecting' message. Again, no message of any kind when selecting the Freedom Pro Keyboard.
Have tried unpairing and re-pairing- no change. Switch is set to SPP, keyboard is on, just nothing. Ideas? Wondering if it's just a bad keyboard. It has to be sending something as pairing with my phone requires entering a 6-digit, randomly selected pairing code. Beyond that, nothing. Any help appreciated.
Welcome to android central. I would post this in the device section to get some more direct help. But it might be the keyboard is not compatible with your phone.
Sent from my Xoom using Tapatalk
Reactions: yankeesrock
Got it to work- not sure how as I didn't do anything different this time around. It works reasonably well and most of the buttons work as they should. One issue though. I keep toggling the language unintentionally while typing. Usually when I go to type "I". It switches to Korean which is annoying. Only way to toggle back so far is to go to settings and change the language there. Any advice on how to toggle languages using the keyboard keys? Thanks.
Freedom Pro keyboard- Language Toggling.
Turns out if you hit the space bar, shift, and "i" at the same time the keyboard will toggle to Korean. Doing the same thing again toggles it back to English. Looks like it's a bit of sloppy thumb control on my part that I'll need to correct as I keep toggling unintentionally. Pilot error, perhaps compounded by a less-than-desirable keyboard "feature".
Final post. I submitted a help ticket on the Freedom company website, and received a response back within an hour. One more exchange, and the keyboard is running without the horrible shift/space language toggle. Deleting my existing driver and re-downloading and installing worked like a charm. Overall, the keyboard is much faster (for me at least) than struggling with the virtual keyboard, and makes the phone much more useful for email exchanges.
Now if they could only incorporate repeat on the keyboard/driver, that would make it even better but overall, the keyboard functions very well.
amaka
