Freezing problems :(
Shanicenicolle
873
So since the Jelly Bean update my phone will randomly freeze then the screen will turn black. It stays like this until I either pull the battery or hold the power button down.
I am rooted so I thought maybe it was something I had modified. But I did a factory reset last night and then it happened again about 2 minutes later. In the past day it happened about 8 or 9 times.
Anybody have any clue as to why or are having a similar situation?
Edit: I've read that using Chrome fixes the issue, but I've always only used chrome and still have this issue.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
ybcthanerd
302
I do think think a factory reset resets ur root. U might want to look at tha place where u got ur firmware
Sent from my SGH-T999 using Android Central Forums
Shanicenicolle
873
Also y did u root wut did u want/need that stock didn't give u
the reset doesn't root and a few apps i use require root access. And my firmware came directly from kies... so I don't think this would affect anything.
- - - Updated - - -
Read on other forums that some folks were experiencing fried motherboards...
sent from a Galaxy far away
The fried motherboards caused phones to not respond at all. I was able to get my phone working again by going back to stock. Thanks tho!
ybcthanerd
302
Yep I thought it was a bad root sum of those roots mess ur phone up
nataspaparker
