Froyo problems solved...
wabyrd
346
8
Problems I was having with Froyo:
Missing apps in market (most notably slingplayer)
FC whenever I clicked on the battery image for usage stats
Solution:
Hard reset from boot screen
Factory reset from privacy menu. (I did this factory reset because after just the hard reset, the phone seemed to lag a LOT).
My apps are all back in the market now. No lag.
Have decided against using Battery Left widget as that appears to be what is causing the force close issues in the battery manager.
End result: Squeaky clean install of FroYo and it's working perfectly now!
I experienced the same lag after the hard reset. I'm going to try your method. Thanks for the tip. Which order, just out of curiosity?
ruhidubey0188
