"Fully Charged, Unplug Charger" Notification is Overheating my Phone
Re: Re - Which is the best charger to use for s4?
Am I missing something or is this a Android Bug? Usually Developer option is usually hidden in a new phone. I also had the same problem, developer option was on and screen set to stay on while charging :(
So when charged overnight my screen stayed on for several hours. Is this a bug or my phone was not 100% new?? Did it damage my screen? At least it was dimmed because it was dark...
Helllo i have a problem with samsung duos.my phone speaks up saying that your battry is overheated.does anybody have any idea about this?????? I feel dhat my phone is going to brust any moment.
Take out the sd card. My phone used to overheat when it was being charged and the battery ran out within 4 hours. Took the sd card out and have no problems at all now.
You can open dev. setting going to settings and tap on build nr. 7times. After this it should be available under settings menu.
Rosie67
