G1 won't turn on! Help!
ALFRITO
My phone was working fine earlier today, and I turned it off for a moment. When I tried to turn it back on, it vibrates, and the screen lights up, but the Android or G1 logo don't appear and it never gets past that.
I tried doing a factory reset, but the triangle and exclamation point never pop up, and I never have the option of resetting or anything.
Is there anything I can do?
Hi could be that your screen has gone this happened to me occasionally but it usually came back on.
A few suggestions, try press and hold the camera button on the side and the power button together till the phone switches on, you should enter fastboot mode, if it powers on but no display try pulling the battery then boot as normal, the phone takes a few minutes to boot but just before it boots fully the buttons light up for a short time, if this happens then you know your phone is booting fully and its your screen thats faulty most probably the ribbon easy ans cheap fix. let me know what happens.
Sent from my SpeedTeam Dream using Tapatalk
i hade that issue i sent mine back to HTC for service and they told me that parts was backordered and as soon as they get the parts in i would receive my phone back
