• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
g3 brand new battery drain
A
AC Question
i just got an lg g3 replacement - BRAND NEW
i had my data backed up on the sd card from the old lg. so i inserted the sd card and restored everything. it took a longer time than expected. the result of all this is i've been fiddling with the new lg for about 3 hours, what with all the backups, dickering with some apps adjustments, and the phone resetting about 3 x.
during this time i started to notice my battery drain with every passing minute. at one point 85%, then 55%/ one time the phone turned itself off and when i started up, the battery went from 55 to 25%!!!!. this was no normal restart as i had already completed all the necessary initializations. in fact the phone turned off twice unexpectedly.
nothing noticeable in battery usage except dex2oat, which i read is to be expected initially. stuff like wifi and bluetooth, brightness, location et all are all turned off.
i'm getting a little worried about this drainage as i had NEVER experienced this kind of thing before(and i have switch phones a few times)
any help would be welcome.,,,,or am i worrying about a normal process with initial phone diddling
thx
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,080
12
38
Battery drain, or at least indicated battery drain, of the kind that you describe is not normal.
