Galaxy Gear wont charge or turn on
ginoancona
4
I haven't use my Galaxy Gear in a week I tried charging it and it doesn't turn on at all. I tried chagrining it for over an hour I tried holding the power button and nothing. I what to do a reset but it doesn't turn on at all so is there any way I can do one when its off. Any one knows what to do or what you guys did to your to turn back on. PLZ Help me ..... THANK YOU
I was having the same problem mine went dead an would not come on no matter how much I changed it so I went on Google seen that other people were having same problems with it one guy said get a charger that fits the cradle an the other end be USB an plug it into my computer so I did an it didn't work right then so I kept it on there all night an when I woke up I tried to turn it on an it came right on the computer is a slow charge but it worked maybe this will help
I am using a gear for more than an year, however my gear was not active for more than a month and when I decided to use it again, I have experienced the same issue, the gear was not charging at all. I started googling and found this is an issue with gear if you are not using it for long.
I found multiple solutions like opening a watch and disconnect the motherboard/battery and reconnect or hard reboot while connected to dock, however the solution looks scary as we are actually opening the watch, I was not sure with warranty after opening the watch as well.
I found one more solution, which was pretty easy and handy. The solution was “Charge using your computer/laptop”. First I tried with a computer, however it did not work then I tried with Laptop and IT WORKED. The only difference between Computer/desktop and laptop was the admin rights. I have admins rights on Laptop.
I am looking for technical justification for not working from AC charger and working from Laptop USB, but my issue has been resolved. Thank you my laptop
cbum63
