Galaxy Gear working after being submerged in water.
That's good to see. One of the complaints I always here is that the GG is not water-resistant. Looks like it is more so than many believed.
It _is_ water resistant......not sure why so many reviewers said otherwise. It's IP55 rated, says so right in manual.
Out of curiosity where does it say it on the manual. Everything I see in the included booklets is don't get it wet.
GALAXY Gear is certified IP55*, protected against penetration of dust and water splashes from daily use. IP55 rating means that device is protected against penetration of dust in quantity to interfere satisfactory operation and harmful ingress of water under test condition of spraying the enclosure from any direction with a stream of water from a standard 6.3mm diameter test nozzle for up to 3 minutes. According to accredited test results by Korea Labouratory Accreditation Scheme, individual results may vary.
GALAXY Gear - FEATURES | SAMSUNG
Thanks for the link. For a while there it seemed like Samsung was being silent about the issue. Good to see they finally put it on their website.
tao17
