Galaxy Nexus signal icon grey, BUT still connected?
onelegchair
14
So I did a factory reset on my verizon Galaxy Nexus, and when I restore all my stuff with Titanium Backup everything is fine except for the fact that my signal icon is now grey. Now, I know that normally a grey icon means no connection and blue means you have a connection, but I have a perfectly fine connection, but it's just stuck grey. I've tried a number of things, and I can't figure out how to get it back to the grey when not connected/blue when it is state. I know it's a minor complaint, but I'd appreciate any help. Thanks.
The signal will be grey but when connected to 3G it will turn blue.
are you seeing grey even when 3G is turned on?
I did a factory restore last week. so I am sure that how it was designed.
Yes even when I have full 3G/4G and wifi even. It's not the regular turn grey when there's no signal. It's just constantly grey regardless.
I was curious about the color as well (I have the GSM version). Based on my reading on a few forums recently, I learned that ..the blue color indicates google account sync activity. If you are not connected to the google servers, then the icon is grey. The bar levels indicate the signal strength.
This. Did you flash a ROM? Did it have gapps?
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Have a you looked under Setting/Accounts (specifically "Google") to be sure the phone is syncing with your Google account?
This is a good place to check. Lots of people report that being signed out of Google Talk is often the culprit too.
Digital Dude
