Galaxy Note 10.1 and USB Hub
Dale_M
525
Was wondering if any hardware people have used a powered USB hub to run multiple USB devices off a Galaxy 10.1 (2014) with Android 4.3... Sort of visualize a powered hub (to supply power to USB devices) and not "load" tablet with excessive power drains on battery...Anyway USB hub plugged into tablet via proper cable connections ( USB to micro or maybe some adaptation (OTG cable?)) and then devices plugged into hub...Kind of visualize this in a docked situation where you might have a printer or keyboard or game controller or flash drive (or all the above ) connected to table ....
Any thoughts or concerns.... Trying to possible integrate and use some of my 'old' technology into the brave new world... What am I missing here besides "device driver" that are incomparable or may be nonexistent...
Cheers!
Dale
Cheers!
Dale
I would imagine you will see significant battery drain depending on how many devices are connected and how much power is being pulled. Also, check the required power output needed to supply power to the USB hub and see if it will even work with the device.
Think you missed the part where I mentioned a "powered" USB hub (has own independent power supply), to power USB devices to prevent power drains on tablet...
Dale
Mdean2030
