Galaxy note 2 battery questions...
umer yes
6
i got my note 2 yesterday and i used it the whole day with wifi constantly on(browsing), listening to music, with sync off everything is perfect the only that bugs me is the fact that it only lasted 5 to 6 hours.Does your note 2 last the same when using it heavy or is there something wrong with my battery or phone? and one thing more, when i view my battery drain apps, google chrome is usually the 2nd or 3rd on the list, is this normal? honestly i was expecting much more from this phone battery wise....thanks
iOS Gravity
367
Normal with wifi on. It drains the battery a lot. Make sure that gps is off. Chrome is probably on the top of the list due to you using it to surf the web a lot. By the way, I think it was unessesary to have started 2 threads on one topic.
nlitenme
545
Welcome & congrats on getting your N2!
Batteries normally don't come fully charged from the factory. Also, they usually take a week or so to build up to their max usage time. Give it some more time.
And like galaxyboy said, you don't need to create multiple (I see 3 so far) threads for the same subject. The mods are very good about making sure they're in the right place.
MicMike
