• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Galaxy Note 3 LED Flash not working..
Marcin Stachurski
118
Every once in a while I notice I can't use my "Assistive Light" feature or the flash while taking photos. I then reboot the phone and it works fine. What's going on here? I haven't downloaded any new apps in the past week or so (it's been happening for about a week). I can say it started happening around the same time the Google Settings icon got changed. Anyone else have this annoyance?
STARGATE
Ambassador
Oct 8, 2012
6,587
Hello Marcin, have you checked the flash settings?
How about the camera mode?
There are modes that will disable the flash.
Please check and let us know.
Marcin Stachurski
118
Should've preceded with "I'm not new to the technology game and am quite the techy" lol. Has nothing to do with that. My "torch" or "flashlight" app doesn't even work when this happens. So strange right?
STARGATE
Ambassador
Oct 8, 2012
6,587
Have you tried any other torch app to see if that works?
If it does, the problem could be software related.
It could be a hardware problem too.
I have heard of problems like that before but never seen it personally.
I'll ask the other ambassadors if they know any fix to it.
Marcin Stachurski
118
Actually specifically downloaded 3 or 4 flashlight apps to see. Wiped all the cache off of them, but when it happens, none of them work.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,253
If you remove the apps, does that change anything?
Sent from an AOSP M8
Marcin Stachurski
118
Well the Assistive Light is part of the Note 3 interface so I can only disable it. It only returns the flash/led light to working after a reboot. And then a few days of regular use, doesn't work again. I think it's time for an oPo
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
I'd back everything up (and I mean everything), then reflash the phone. I don't know what carrier you have, but if you can do an Odin flash, the AT&T 4.4.2 files are at N900AUCUCNC2 ODIN Files - Post #136 - XDA Forums (Don't use the all-in-one - that restores Android but leaves your data intact. The individual files give you an out-of-the-box phone on 4.4.2.) If you have a different carrier, look on XDA for a full flash for that carrier.
