Galaxy Note 4 and Galaxy Note 3 do not power on
Canvas26
After connecting a brand new 10 ft USB cable to my Galaxy Note 4, it charged my cell phone up to 90%. Immediately the phone turn off by itself. Now it doesn't turn on. Afterwards, I connected the OLD cable to my Galaxy Note 3 and the cell phone started charging. I disconnected the OLD USB cable and inserted the NEW 10 ft USB cable, and my Note 3 stopped charging immediately and didn't power on anymore.
I have a second Note 3 battery and inserted it to the cell phone, then connected the OLD USB cable and started charging again. I didn't connect the NEW 10 ft USB cables because I knew it was going to messed up my battery.
My question is: How can a USB cable, NOT the charger, can damage my batteries that way? If this happened to someone else, please provide some comforting advice on how to possibly fix my problem, or maybe I should buy a new Galaxy Note 4 battery and throw away this dangerous 10 ft USB cable.
Cable description:
Airsspu Micro USB Cable,4Pack 3FT/6FT/6FT/10FT Long Premium Nylon Braided Android Charger USB to Micro USB Charging Cable Samsung Charger Cord for Samsung Galaxy S7 Edge/S7/S6/S4/S3,Note 5/4 (Red)
Thanks.
The cable can't, since it's not directly connected to the battery. Measure the battery voltage on the Note 4 battery.
It's possible that the cable could somehow damage the charging circuit, but that wouldn't damage the battery, and you'd probably have smelled smoke. (Take the Note 4 to a repair shop. See if they have any old Note 4 battery that still sort of works. If it does, even for a minute or two, get a new battery (they're cheap). And ask them to check the cable.
boone
