Galaxy note 5 problem,need help!!
bshote
11
hello
my note 5 is suffering from battery drain and cable charging instead of fast charging
i got the original cable and wall plug also tried it with my brother phone and its says fast charging
what i did: i changed the battery
and changed the charging port.
Note: i can't connect it to the computer.
p.s: the phone was rooted 1year ago for a couble of days then i unrooted it.
Samsung galaxy note 5 running marshamello 6.0.1
Have you questioned "my friend is a technician he changed the battery and the port (all original)" - if you can't connect to the computer, sounds like an issue with the port which could also be your charging issue! I seriously doubt that the previous "rooting" has anything to do with it!
Call CenteAgoda Indonesia
