- Dec 18, 2012
- 2
- 0
- 0
If you are having issue with the S3's battery draining unusually fast, the problem is Samsung Link. You cannot uninstall the app. All you can do is uninstall the updates and ignore the updates Google Play tries to send you. Samsung Cares tech support says "this is not a known issue". Hopefully, they will "Care" soon and fix the issue!
BTW. I have AT&T and Jelly Bean 4.1
