Galaxy S4 battery problems.
SamsungS4User
So i bought my galaxy s4 a week ago and it was fine but i took out the battery to let it rest cause it was getting hot. After I put it back in the battery started dying when I wasnt doing much.
In 6H and 10M ive used 54% of screen and apparently 12% on device idle. I dont think my device idle should be that high. Any solutions?
Check to see if there are any updates available. Also try a program called Snapdragon Battery Guru and see if that helps with your battery life. How much do you use the phone? Apps, Calls etc...
Are those results from the battery usage stats? If possible, please post a screen shot of that setting.
Sent from my SPH-D710 using Tapatalk 2
7Unlock
