Galaxy S6 Edge - Apps Edge screen won't open?
  • Start date Start date
A
AC Question
Galaxy S6 Edge - Apps Edge Screen Won't Open
I have the Galaxy s6 Edge, and I use the "Edge Screen" feature (Settings - Edge Screen). I have the following settings:
Edge Lighting - Off
People edge - On (with selected contacts)
Apps Edge - On (with selected apps)
Information Stream - Off
The issue I am having is that after a period of time (seems random - sometimes it's a couple hours sometimes it's a day or so), the "Apps Edge" screen will no longer open. I can see the tab on the edge of the screen, but when I try to swipe it open, nothing happens.
If I go back into settings - Edge Screen, and simply move the "Edge Screen Position" to the opposite side and then back again, it works properly again.
Is anyone else having this issue?
This is a brand new phone. I've tried removing all of the apps from "Edge Apps", and adding them one by one. It does not seem to matter. After a while, the edge screen will stop working until I change the edge screen position.
Re: Galaxy S6 Edge - Apps Edge Screen Won't Open
I am having a similar problem. Moving the edge screen tab wont fix it, I actually have to restart my phone. Edge screen a waste of money.
Noob
