Galaxy S6 edge : battery is terrible
It's early but my at&t one could be considered pretty crappy thus far.
My battery life has been pretty decent on my ATT s6 edge.
First full day. 36% left 16.5 on battery, 3 hours screen on time, and 1 hour talk time. Google services used 13% of the battery
I only Web browse, YouTube, google+, and hangouts
I think this takes the cake for the best I've seen yet! Do you mind giving a little more info as to any tweaks you may have made or what type of usage you do?
No real tweaks. I do try to turn off Bluetooth and location when I'm not using it. Just a habit. I do have Google now on. I'm on AT&T. WiFi on
AT&T: only 8hrs in mostly on WiFi, cell standby is showing at 2%, BT and WiFi on all of the time
Alright so after turning off wifi I don't get cell stanby drain anymore
I also had the s fit app tuning and I would like someone to tell me if I should turn it off
Then I turned wifi on and this happen
Mine has been good. Only thing I have on is location services. Wifi off at work. On when home. Check email manually and get Facebook updates/notifications automatically. 15 hours 23 minutes now with 58% still left.
nemismom
