Galaxy S7 and Samsung Gear VR - Oculus Installation problem
SBeliveau
3
Galaxy S7
Every time I start the Oculus Software, It tell me that an "Update require"
I have the latest OS. And I already try to uninstall, reboot and reinstall multiple time.
Does anyone experiencing this problem ?
At my first install, the Facebook service was disable. I have re-enable it and restart all the process, but I still have the same issue.
Galaxy S7
Welcome to Android Central!
Did you disable any other apps other than the Facebook app?
Yes AMAZON
FaceBook
Instagram
mobiXpress
OneDrive
OneNote
Skype
WhatsApp
I'm very busy presently, but as soon I have time, I plan to do a hard reset.
The people "Support" of Oculus are useless, they tell to call my provider.
I offered to oculus to run a debug but no answer. I'm really disappointed.
Thanks for helping
OK, I found it, it was com.facebook.system that was disable, but it doesn't appear in the app list. So when I try to start the facebook app, it ask me to re-enable it. After that, I was able to do the update.
What a peace of ch t
Thanks a lot, you put me in the right direction.
I have the same issue. through oculus on vr it will download but won't install and then prompts to download again. I don't see anywhere the .com.Facebook and all the apps are enabled. can anyone help?
I have the same problem, but only inside the VR. I can install viewing the phone normally through the store.
What a pile of junk mines the same complete joke oculus dont know their arse from their elbows the people who are there to help havnt even got a clue all they are doing is looking through forums themselves if anyone has found a fix to this very anoying problem could they be so kind to post please i have a galaxy note 7 and the vr2 and i cant help thinking that the best thing that could have happned is to clip the phone into the vr and hope they both blow up not just one of them
I have the same exact problem. The only solution I found from the Oculus website was re-enabling the Facebook app installer, which I couldn'the find anywhere. I'm really hoping someone knows how to fix this.
Go to settings
Applications
Application Manager
Scroll down and make sure “com.facebook.appmanager is enabled
Then top left corner tap more show system apps
Scroll down and make sure com.facebook.appmanage is enabled
Took me ages to figure this out hope it helps
king von
