Galaxy S7 Edge - QI or PMA Charger
TMavC5
1,605
389
83
Just want to make sure if anyone know if the newest S7/S7E is QI or PMA for AT&T?
Re: QI or PMA Charger
It is actually both. You can use either standard with the S7/S7E. It was that way with the S6
Is there any real advantage to either one?
I had both for my s6 and found the qi to be more reliable than PMA. The PMA was way more finicky about placement and it would always disconnect.
Yes, QI by far better and PMA sucks because sometime it won't charge when you think its charging. Hate it!
lalarat
