galaxy tab 10.1 p7510 problem help!!!!
Petros Solomos
4
Hi!
My P7510 is freezing and turn of by it shelf, when I turn it buck on it always start from the same point, even if I delete everything when it turns on they reappear.
I have tried factory reset, hard reset even odin but nothing works it always come buck to the same point.
Hi!
Welcome to the forums. So, to clarify, you reflashed a ROM with Odin?
I have just tried with checked re-partition and then with checked nand erase but odin fails both times Im starting to think that there is some problem with the internal memory.
I think you may be right. Especially if Odin is not fixing the problem.
Sent from my HTC One_M8 using AC Forums mobile app
Is there a way to replace the nand?
I am not sure. Physically you should be able to replace the memory, but that most likely would require replacing the whole mother board.
dumpsterrentals101
