Galaxy Tab Pro 8.4 tablet no power - no charging, how can I fix it?
mattman1310
Need some guidance here, I'm at my wits end:
Galaxy Tab Pro 8.4 - over a year old - OUT of warranty
No charging (I assume) - will not power on - yes, I've done the power + volume + home button - still no work
I have replaced the battery - still it will not turn on - I figured it should since replacement batteries come with some sort of charge
I've done some reading, the charging port can be an issue, so I thought about replacing that but I don't think that should be an issue BECAUSE with a new replacement battery, it still SHOULD power on?!
Yes, my cable and charger are in good working order because I have used them to charge other devices...
Samsung wants a $284.20 "holding charge" on my CC for repair? Are you f***ing kidding me?! Of course, they will refund the difference in the repair should it be less...
ANY HELP IS MUCH APPRECIATED!
Re: Galaxy Tab Pro 8.4 tablet no power - no charging
Welcome to Android Central! You should also consider that the power button could be faulty.
Joltpost
