GB Camera fix help
cajunbeast
127
I can't seem to find the camera fix zip in order to flash it. I'm running Gingeritis 3D and that is my only issue.
Does anyone have it and will share it?
Thanks.
Sent from my ADR6400L using Tapatalk
Yes. All those links were broken. I've found a tin of threads. Just haven't found a good download. I don't want to subscribe to 20 different forums just to obtain a file.
Sent from my Thunderbolt.
Hey Jeenyus, I'm not a member of bamf. So an email would be awesome.
Cajunbeast813@gmail.com
just a bit of warning:
this zip will fix the camera issue
BUT
you will be sideways in G-Talk.
fair tradeoff, i suppose. but i hope a more permanent/correct solution is found.
it just hit me yesterday--so i applied the Time/Date fix (change date of your phone to August 1st) and it worked fine. but applied the zip anyways & confirmed the sideways G-Talk issue.
I believe it might be your rom, have you tried to reflash it?? If not try that, and if you still have the problom try a different rom.
The link I gave allows you to download file without setting up any membership.. And be the way this was posted on one of the post I reported was on the same page as this thread.
Jokerman
