GB+GPS=FAIL Help!
Jun 4, 2011
40
7
8
After the GB update, my location for my apps is WAY off. About 100 miles. Is there an app that will make my TB lock on and know where the hell it is?
Thanks,
Rob
Can try GPS status from the market. Once its installed you can run it and it'll download GPS assistance. You can also go into the setting and clear the cache and re-download at anytime to try and help.
I would consider a factory reset if its not too much trouble though because you shouldn't be having issues. GPS has been awesome for most folks from what i've seen on here since the GB update.
Reactions: ThunderboltRob
I can confirm that GPS is working great for me since the GB update. I used it for navigation all over St Louis when we were there on vacation and it was perfect. Locked in within ~15 seconds and it was dead accurate.
Ninja01
