- May 17, 2010
- 9,267
- 496
- 0
With the update rolling out from T-Mobile I thought it would be appropriate to have an issue/problem tracking thread.
If you have the OTA from T-Mobile (not the leak from LG) post any problems you're having here.
Sent from my LG-P999 using Tapatalk
Issue #1: LG camera app missing in the Gingerbread update.
Solution: Dev's have ported it to Gingerbread. It still has some quirks, though, but they are working hard to get it perfect.
Issue #2: Some people are still seeing the authentication error when trying to update.
Possible Solution: Uninstall and reinstall the LG update software. May not fix the issue.
Issue #3: Refurbished units are not able to update.
No known solution.
Also, the LG "leak" and the T-Mobile release are the same, I just didn't want to create this thread until it came from T-Mobile.
No known solution.
